1 - 16 of 16 Posts
What is the best type of material to use for making u bars?
What type of material should i use so that i will be able to solder a stabilizer bar to the top to avoid the axle wobbling around?
I was just wondering because i am building my first styrene hopper chassis and i just tried to solder a piece of metal coat hanger which is my u bar and it wouldnt solder to it?
Is there a special type of material i need to us to get them to connect to each other to use as a stabilizer bar?
you know, i've tried soldering brass before using just normal solder and iron and had no luck at all with that. im not sure if there is something special you gotta use or do for it. :dunno:
sorry i cant be much help here but im trying ;) lol
i'm building my frist actual hopper/dancer chassis and just went with T slidders on it :biggrin:
How did you make T-sliders? Maybe i will just make t sliders if they are easy to make or what not.
But is there anyway you could post a picture or diagram up?
To solder to meatel you need meatel solder.
-twin
they're around 6-7 bucks at the hobby shop. sliders, guides and axles all together ;)
I use Brass Rod, copper is nice, but seems wreaker.... atleast to me is does. T-sliders are great, unless you do a "spider leg" for a dancer setup....
actually, i've had more of a problem with u-bars coming through the hood. When it gets lots of air and comes down, eventually the glue gives and the hood just flies off. looks kinda of cool though! :biggrin:
if u glue the hood down then the tslider wont come all the up and the front wont lay. thats the prob with the hh dancer.
I used to use weldingwire but I'm totally converted to brass since it solders very easy. Get a medium soldering iron and solder where you can fix up larger items with like candleholders and stuff..just ask the guy at the store that you want to solder rods.
I also use the acid stuff..but be very carfull with it just put on a little bit and after you soldered wash it with water and soap. ;)
1 - 16 of 16 Posts
