1 - 20 of 27 Posts
I jus want to learn how to make them so I do not have to make alot of swith box: Please help. :confused:
I used one of those red and black speaker quick disconnect terminals from Radio shack. Instead of wiring everything straight thru, each motor wire has its own clip to go to. If no one else posts about it, I'll try to post some pics later.
K. Diaz
So I should by a VGA male/female connector. What about the adapter. So instead of wireing the motors straight to the motors I would wire them to the VGA connector. Then wire the switch to some sort of adapter. What kind of adapter.
p.s. Why 8-10 wires
p.s. Why 8-10 wires
I'm not sure about an adaptor, but you're supposed to wire the motors to the male, and the switches to the female, or the other way around. Each motor has 2 wires, one for negative, other for positive. So a front back setup would have 4 wires, dancer would have 8. That's the normal stuff, more crazy setups have more motors.
K. Diaz
Banned
Originally posted by jevries@Jul 21 2003, 09:31 AM
Twin did you check the pics of the Rollin' '63?
You can see I use a computer VGA male/ female connector to hook my cars up. I use 12 up to 20 wires (bundled). For a rolling setup I use 8 to 10 wires and cover it with spiral coverhose so it stays flexible for easy driving. ;)
can it turn?
1 - 20 of 27 Posts
