I may be getting a pump that I am not certain of it's brand or quality. I will try to add a pic of it if I can, but will describe it as best as I can. On it it has enscribed "L S H" (then below) has a picture (below that) says "Wicked". It has 2 square things on top, I believe they' are the solenoids (hard to tell from the pic) with 1 hose coming out of each that connect to a common fitting and then leads back into pump where it reads "Return". Where the solenoids are they connect to a fitting that goes into pump where it reads "Press". Then below that has a nozzle that read "30 PSI Max".
Any ideas what brand this may be????? PM me for some details.
Thanks in advance!
Thanks in advance!
