WHATS THE BEST WAY TO REMOVE THE UPPER A ARM ON A 64? DO I NEED TO REMOVE THE STEERING SHAFT OR IS THERE A EASYIER WAY?
JUST POP THE BALL JOINT, UNDO UR BOLTS, KEEP TRACK OF THE SHIMS AND WHERE THEY GO,CAREFULLY TAP THE END OF THE BOLT WITH A HAMMER AND THEY WILL SLID IN ENOUGH SO YOU CAN PULL THE ARM OUT :biggrin: :biggrin:
Not necessary, if your your driver's side arm has never been removed you can always cut down the bolt for removal clearance.
