1 - 2 of 2 Posts
should i reinforce n extend the top rear trailing arm on a g body also should i reinforce the rear lower arm or dont it make much difference
im gunna be runnin 14s in the rear with a coil over set up or could i fit 16s out the back n still lay or would they be too long for the trunk
extend the upper 1inch and shorten the drive shaft 1 inch and renforce the lowers and you can put 16 and still lay low try to get them side ports so it dont hit the deck when bang a 3
1 - 2 of 2 Posts
