~Individuals CC~
I need to fix a couple imperfections on hidden spots.
Can I use the KBC of the same color?
is the car you are touching up on painted by UK or KBC (Kandy Basecoat)?
If it is KBC, then there might be a chance.
If it was painted by UK, then I dont recommend it. KBC is a different mix. If you put a container of UK and KBC of the same color beside each other, there will be a big difference.
~Individuals CC~
Its a UK. But the places I need to fix are hidden behind chrome and the license plate. Very small.
What do you recommend for a touch up spot repair?
HOK does have a video on how to touch up and blend in repair jobs on candy.........something to look into.
But if it realy is just some small somewhat hidden areas.......I say give it a try....it couldn't look any worse then it is now, and if it doesn't look good you could always sand and start over with a new method
