do it in a datsun!!
ok i havet delt with air ride in about 3to4years so i need someone to bring me up to speed, i dont know too much about electronic valves because i always used manual, anways i just bought 8valves mounted on a aluminum block,
1.The shaft appeards to be bent,is it suppose to be like that or should i bend it back?
2.what are the plugs for, gauges maybe?
3.does anyone know the brand, psi rateing or size,im pretty sure its 3/8s since it has 3/8s hose fittings on it
4.do u think i will have problems with the valves sticking shut or closed in the winter,
air valves 3 position
300psi 3/8 competition 4- valves mounted on
$299.00
Yes the small holes above the airlines are for guages.
Its from aim industries
Face Puncher
shaft shouldnt be bent, send it back for a new one...
it will hang up constantly, even if you bend it back...
