1 - 12 of 12 Posts
I am looking for pictures of a five gallon tank with the valves (parker) mounted on it. Since the ports are so close together, I need to know what types of connectors and fittings to use so I will be able to tighten down on them without hitting the valves next to it.
Btw, it's an 8 valve setup.
Any help would be appreciated :cool:
how about this?
you can go here for you fittings, they deliver pretty fast.
http://www.fittingsandadapters.com/pustubfitfor.html
You will need:
1//2" straights - 8
1/2" tees - 10
1/2" to 3/8" nipple for the water trap - 1
3/8" straight - 1
3/8" to 1/8" adaptor for the compressor line (from compressor to water trap) - 1
either 1/2" to 1/4" or 1/2" to 1/8" for pressure gauge/p switch - 1
I'm a bit lazy to tell you the rest but you get the idea right?
I'm sorry, the tank is an eight port tank. Here is a picture:
My problem is that I want the valves to be on the tank but the 4 ports on the front are so close together that the valves would hit each other if I tried to put them on the tank.
Check out this setup....how did he get the valves on this tank without hitting the valve to the right of it?
Dismantling the solenoid valve is the official way to do it. It's even in the Air Lift Company EasyStreet fitting instructions.
You install the outer valves first, then dismantle the inner two valves and fit them that way.
Mike
BOSS
Originally posted by aleigh-n@Jul 25 2005, 12:28 PM
this is just a theory, but what if you unbolt all of these on the valve. you would be left with the bottom piece and would not be removing the noid.
[snapback]3474127[/snapback]​
yeah that used to be my trunk>> i had to remove the four allen bolts cause the rod inside the solenoid stilll sticks out too far so thats the way you have to do it....just make sure you put the diaphram back in rite way>>>lemme tell you tho the 5 gallon tank sucked ass>>>i would be at like 250lbs and would hit it twice and it would go down to like 130-140 ...i went to a 10 gallon and its 10 times better
1 - 12 of 12 Posts
