1 - 15 of 15 Posts
i am gonna be sand blasting my frame this weekend and i dont knwo wat sand to use or where to get it? also how good does sandblasting it work or is it even worth it if theres a easier way let me knwo thanx
that was the only kind i could get from the hardware store they said no more silicon
they also told me silicon sand is bad for la raza
Originally posted by michaels29@Oct 12 2006, 02:56 PM~6356819
i used black oxide i think its called i bought it at menards 50lbs for 10.00 good for rusted steel :biggrin:
it was at Tractor Supply this week for 6 bucks a bag ;)
stylish muthafucka
I used Silica sand for mine, bought at Menards.
i heard walnut shells was good because it does not remove any metal like sand or other sand products. :biggrin:
thats were i got mine :biggrin: :thumbsup:
59 imp 64 imp 77 mc
I use silica sand but anything listed will work
thanx but im juss wire wheelin it wit a grinder type thing its workin ok the thing is im not seperating my frame from my body cuz i dont have enough room where i am so im juss really gettin wat i can wit a jack and some stands ill post pics on how it goes later
Use a blasting sand available from Menards called "Black Blast" it is a pretty aggressive Glass / SLAG media ........... I use it all the time , Cost around $5 for a 50# bag....
It does however have small glass particles that will embed into your skin if not protected & will cause you to run for mercy if some manages to get in your eyes!!!!!!!!!!!! Its hard to get out !!!!!!!!!!! Makes you cry out a mississippi river !!! LOL
I use a very tight fitting pair of safety glasses & then another set of "Over the eyewear" style or a full face mask... WITH A hooded sweatshirt drawn tight around your face , A good set of leather " Mechanix gloves", & an old paint respirator !!!!!!!!!! YOU Dont want o breath none of that shit from any sand blasting material what so ever !!!!! Silicone is no good in the lungs................
you can recycle it too buy capturing it in a corner of a garage floor & then using a 20 gallon tupperware bucket & an old household screen from a window ....... ALL you have to do is shovel/ sweep what is on the ground & sift it thru the screen into the tupperware or bucket !!!!!!!!!!!!
Hope that helps you out man ....... & i hope you have a pressurized sandblaster -- A siphon system aint that effective except on small parts
1 - 15 of 15 Posts
