41 - 60 of 89 Posts
The model two looks great. Will there be a 63-64 impala model two version? Also will it come out early January or late January 2012? Cant wait to pick it one up.
Thanks! The Model Two will be available in all of our current solutions except for the Apache series trucks. Unfortunately We had to push back the release date. Stay tuned!
:D
Check out our new SUB8100 powered sub! Available Now!
Retrosound’s new powered subwoofer is an excellent addition to your classic vehicle’s audio system. The compact footprint and powerful bass response will allow for behind the seat mounting options for pick up truck owners, under seat mounting for bench or bucket seats and numerous other in - car applications. The rigid die cast aluminum chassis and powerful Class D amplifier allow this sub to reproduce low frequencies down to 35Hz.
sub8100 box shot final by RETROSOUNDUSA, on Flickr
Specifications:
Amplifier Type: Class D Power Supply Voltage: 10.5 - 16.0 VDC
Amplifier Stage Output Power @14.4 V: 100 Watts RMS / 200 Watt Max S/N Ra o: > 100 dB Input Sensitivity: 100 mV - 6.0 V Frequency Response: 35 Hz - 100 Hz
Total Harmonic Distortion: 0.08% Filters Low Pass Filter/Slope: 50 Hz - 100 Hz / 12dB Phase Control (variable): 0-180
Other Specifications Fuse: 10A x 1 Size (W x H x L): 9 x 2.75 x 13.74 inches / 349 x 70 x 235 mm Weight: 9 lbs / 4.08 Kg
what size speaker is in that? I hope its a 10 or larger.. 8s cant normally push the right amount of air for low bass.
It's an 8" and hits pretty good for what it is. I've already installed a few and no complaints from any of my customers.:thumbsup:
This is not a "can be heard from blocks" sub. And I wouldn't bury it in a trunk either. This is something that works for cars/ trucks with limited space and great for low fill.
41 - 60 of 89 Posts
