1 - 17 of 17 Posts
Moderator
Originally posted by Skuce2@Jan 17 2004, 01:49 AM
220v MIG
110v MIG will also work...but penetration is a bit less
if u aint gott the jb weld on hand ...u can use self tapping screws....ichbahn style.. :uh: :0
YEAH BUT REMEMBER THAT U NEED TO USE KRAZY GLUE ON BOTH SIDES OF THE METAL BEFORE YOU SCREW IN THE SCREWS.
:roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
I know someone who has used it on a outdoor deck .... that thing can hold a SEMI on it ....... Tough shit ....... Too bad the deck will last longer than the house will........ :0
Moderator
Originally posted by Hmadhopper@Jan 18 2004, 01:19 PM
hey has anyone heard that a arc welder weakens the frame at all thats what i was told or can it work just as well as a 220 mig ? has anyone used one on any car that does some serious hopping and not bent the frame ?
If you're talking about a "Stick" welder, then NO, it will not weaken the frame. "Stick" beads can be found on the largest of construction equipment, they are meant for very HEAVY and durable bonds. I personally don't care for "Stick" beads because they are messy and can be ugly as shit if you don't know how to hold the arc while laying the bead. You can't go wrong with a mig welder, they're clean, somewhat easy to use and will look good with minimal practice.......Still, if you've never welded, consult help.
THE ONLY WAY ANY beads/welds will be weakend is when the weld is still hot and immediately cooled by either dousing/soaking it with water. The extreme decrease in temperature makes the metal unstable and brittle.......
Hope this helps!!!!
L8
Originally posted by hydryan@Jan 17 2004, 08:09 PM
JB weld ;)
j/p
That would be called "Tempering" :biggrin:
Moderator
Originally posted by Skuce2+Jan 18 2004, 07:58 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Skuce2 @ Jan 18 2004, 07:58 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--1 LO 64@Jan 18 2004, 02:49 PM
That would be called "Tempering" :biggrin:[/b][/quote]
1 - 17 of 17 Posts
