1 - 20 of 34 Posts
Face Puncher
less maintence (in most instances)
smoother ride (juice rides smooth with accumulators)
no charging multiple batteries.
no trunks catching on fire
no messy oil leaks
usually take up very little room..
no messy oil leaks
enough for me.
Originally posted by crazy4hydros@Sep 20 2003, 12:36 PM
Air
Leaks which are gonna be a bitch to find
Waiting for hours for ur tanks to refill up
Blowing a bag
Hydros
Fire
Leaks
charging batts
leaks are never a bitch to find........you can hear the "ppppssssssssssssssssssssssssssssssssssss" or you just squirt soapy water over all the fittings and hoses
tank never takes hours to fill it up unless you are blowing into it yourself.
you only blow a bag if your a dumb ass
Originally posted by jumper+Sep 20 2003, 09:12 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (jumper @ Sep 20 2003, 09:12 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--crazy4hydros@Sep 20 2003, 12:36 PM
Air
Blowing a bag
Hydros
Fire
Leaks
charging batts
you only blow a bag if your a dumb ass[/b][/quote]
and you should always keep your fittings to a minimum and use a good brand for push locks
all of the above and hydros require more maintenance and more consummables
hydrofluid and batteries.
i've had both, and in my daily i had air.
short run its cheaper and in the long run its cheaper.
also with bags, you can control each wheel individually and indepently form the others.
:cheesy: ,
cc
u can still have a fire with bags i seen compressers burn down cars but with juice u will have leaks same as air and u will most likely rip or blow a bag i myself like juice i cant stand the sound bags make or haveing to listen to the compresser
hey cruz you can also control each wheel individually with juice
but anyway man just go with what u like more your goin to have problems if u juice or bag it
Originally posted by 216RIDER+Sep 21 2003, 05:46 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (216RIDER @ Sep 21 2003, 05:46 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--jumper@Sep 21 2003, 12:12 AM
hey jumper, didn't you bust some bag on the t-bird :0 ;) :biggrin: :biggrin:[/b][/quote]
:0
i would much rather have a little air leak than a fluid leak. no mess to clean up and no seals to replace. just some teflon tape and a wrench
thats because the guy who installed them is a dumb ass
3 WHEEL.........ENOUGH SAID!
Originally posted by 216RIDER@Sep 22 2003, 01:00 PM
you can do a rolling 3 with bags...
I HAVE NEVER SEEN IT DONE, AND I HAVE INSTALLED ALOT OF BAGS.
NOT SAYING IT CAN'T BE DONE, JUST NEVER SEEN IT DONE.
POST PICS.............
1 - 20 of 34 Posts
