1 - 20 of 20 Posts
I just wanted to ask because I just changed seals from three pumpheads and me and my cousin dont want to blow them anymore. If anyone has any replys please post them cause it was a pain in the ass fixing those pumpheads ;)
Overlocking means to hit the switch again after the car is fully lifted, it increases the pressure and causes seals to blow.
Overlocking is indeed a common cause. Lots of hopping can be hard on em too. You also should make sure your pumpheads are torqued down properly as well. I would reccomend getting a set of SRS Protector valves, they will prevent you from breaking tons of shit, and prolong all of your seals life. See em in this thread:
http://www.layitlow.com/forums/index.php?a...1ddc040f321b512
G
yea :cool:
If you need some valves or would like me to explain how hey work you can call me George Owner of SRS Hydraulics manufacturer of the "PROTECTOR" valves at 517-394-3895 or pm me. Showtime also has them available on there site.
how do you know if your seals are blowen, does it leak out or does your pump lose power? or just it just stop working????
pumphead makes less pressure, and it takes longer to lift ride, and wont work as fast ;)
Originally posted by HiLow@Oct 1 2003, 11:10 PM
hm i might have a blown seal in one of my pumps, my rear pump seems a bit slower than the front...
yeah probably, and sometimes will leak oil into motor :0
how much should a pumphead be torqued :0
Originally posted by caprice man+Oct 3 2003, 10:13 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (caprice man @ Oct 3 2003, 10:13 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Cadillac Bob@Oct 1 2003, 04:06 PM
how much should a pumphead be torqued :0[/b][/quote]
I read once that 25-28 foot pounds was reccomended, and thats where I always set mine to afterwards. I had problems with shredding o-rings before I did that, and afterwards they held up much better. No idea if thats the ideal specs, but it seems to work well for me and doesnt seem to overstress the threads in my aluminum block.
1 - 20 of 20 Posts
