Schumacher: SE-1072
Autozone they have to order it.
how many batteries will it charge at one time?Originally posted by blueouija@Aug 22 2005, 03:52 PM~3671426
not cheap but worth every penny.
http://www.menintools.com/battery/6082.html
Originally posted by blueouija@Aug 22 2005, 04:55 PM~3671735
you can do at least 10 batteries at once with this puppy. I do 4 at a time though...
Originally posted by 357IN602@Aug 23 2005, 12:22 PM~3675584
cool. id rather spend more $$ on a bad ass charger than go cheap. $429 isnt that bad.
:thumbsup:Originally posted by Texas Switch HitterS@Aug 22 2005, 04:24 PM~3671260
Schumacher: SE-1072
Originally posted by adamflow1@Aug 24 2005, 10:53 AM~3681947
is there such thing as a trickle charger for a multi set up? you know like the 2 amp charger for the starting battery on a car that is sitting in the garage? the 2 amps wont over charge but slowly charges to full capacity.
i'm tryin to figure something easy to use, that i can put on and forget about
you mean this one??? ASSOCIATED 9410 12 VOLTOriginally posted by blueouija@Aug 24 2005, 09:45 AM~3682160
the associated will do a tricklecharge that will last for a very long time... it's easy to use as well...
6082 is the one I use... that how I hook it up but I do 4 batts at once though...Originally posted by adamflow1@Aug 24 2005, 02:02 PM~3682896
so you just connect the negative to the neative terminal at one end of the battery bank and the positive at the positive end of the battery bank and let it be. "set it and forget it" :biggrin: ???
Street Chargers suck. They can't keep up w/ a switch happy person, which most of us are.Originally posted by sprgeo@Aug 25 2005, 03:21 AM~3688208
what about using a "Street Charger"? wouldnt that be easier?
