1 - 9 of 9 Posts
I need to know what angle to cut the top of the front bag brackets an the lenghts to cut them front an rear any help would be appreciated
Or if sum ones got a front an rear set for sell hit me up
thats just like a 95 right if it is you want to weld mini centering cup over a donut to center bag in center of frame rails with out rubbing and bolt it down thru top then your cup welded to that donut
okay easy if you look inside of frame the hole is about 3" or so where shock goes thru on gms there is a ring around it that center the cup in place on the fords there is no guide so either u weld a guide in place so your cup doesnt shift or weld it on a top of a cup with a donut
1 - 9 of 9 Posts
