1 - 13 of 13 Posts
SO FRESH!!!!!
what does that stand for on a pump is that the mm size of the port ???? :)
all 3 of those are in one or it that 3 different pumps?
SO FRESH!!!!!
ok so if its just a strret setup you dont really want a high number but a hopper you would want like a 13 ??
yeah sorta, the less power you have (batts), the lower head you can run without bogging to motor down and killing it
Phoenix Chapter President
street setup/hopper setup??????you can hit back bumper with all them gears if your shit is dialed in correctly...........
I have #5 gears for my back pumps and a #9 for my front(lay n play setup) but have only had to take apart a #5 before so i wonder, do the gears have a different amount of teeth on the different numbered gears? Anywhere to find the specs on them such as how many gallons per minute they should flow at 12v, 24v, etc?
thats what im wondering. flow vs psi
its the length or width of the gear depending on how you look at it .. if you look at the side of the pump head the center sections width
the wider the gear the higher the number and more flow the pumps is rated for ..
the wider the gear the more volts you have to use to overcome leverage of a wider gear to get the pressure up
so then i would wana # 9 for my caprice front with 72 volts for long batt life ??
1 - 13 of 13 Posts
