after all this time, getting arrested, and 3 traffic tickets (unsafe vehical, exhibition of speed, and speeding), it looks like i might be getting my setup in as little as less than a week. i have $1200 now and expect to get another $400 this friday. then i can barrow another $200 from my friend Oscar. anyways, here is the list of what im going to get for $1700:
4-HS slam specialty bags (2 6", and 2 8")
12-1/2" blitzluft valves
120-foot of 1/2" line
front and rear bag brackets
4-thomas 337 compressors
2-170 psi switches
2-water seperators
2-check valves
-if i wait another 2 more weeks, i can get 4 more valves so i can do dual 1/2" lines to each bag...
anyways, my question is, what kind of brass fittings you guys recomend i use?? eventually i want to get with a bottle in the trunk, and run about 300 psi. i've seen fittings with big "ribs" that are supposed to anchor themselves to the air line with no clamps at all, and i've seen those with smaller and more "ribs" on them, which require some sort of clamp (if i use these, im going to use the kind you press on with a vise).
which kind do you guys use? which kind you recomend for me?
i was going to buy a 1/2" fitting kit, but decided not too because they were too expensive and im going to need at least 2 of them. i work at a hardware store and can get them for about $1.60 a pop (female, and male 1/2").
so what kind of fittings you guys recomend??
2-170 psi switches
2-water seperators
2-check valves
