Do I use to thin epoxy primer and to clean the gun afterwards?
what kind of epoxy is it? I know on ppg's dp primers you can thin them with the same reducer (dt) used in the base coats. To clean up use lac. thinner.
X2 :)
I think keystone...
GOOD LUCK WITH THAT BROTHA......KEYSTONE SHOULD NOT HAVE LET YOU LEAVE THE BUILDING WITHOUT YOU HAVING A CLEAR UNDERSTANDING OF WHICH PRODUCT TO USE......
BUT IF YOU GOT THE HOME BOY HOOK UP YOU NEED TO GET THE HARDENER FOR IT AND ALMOST ANY REDUCER WILL WORK WITH THE KEYSTONE CRAP.....JUST GET THE RIGHT TEMP.
Haha hold up im kinda slow what you mean? Yea I got the hardener
