1 - 11 of 11 Posts
ya I have 4 pumps 10 batterys right now and running #8 marzzachi
whith 96 volts to the front. but im adding another four batterys this winter so i will run ten batterys when hoppoing in the pit.
where is the cheapest place to get pumpheads
YOU CAN USE THE #8'S IF U WANT THEY WORK COOL WILL TAKE U A LITTLE LONGER TO GET UP THERE BUT THEY WORK AND THEY R BETTER FOR LEARNING TO HIT THE SWITCH THEY R A LITTLE MORE FOGIVING THAN THE #11 BUT ONCE YOU GET BETTER ON THE SWITCH GO TO THE #11 MARZ OH YA AND RUN 7 BATTS TO EA FRONT GATE NOT 10 YOU WON'T NEED IT AND YOU WILL BURN SHIT UP QUICK AND IF YOU ARE THE ONE WITH THE BLACK LINCOLN THAT WAS IN YAK LAST WEEKEND FOR THE BIG HOP OFF JUST A LITTEL FREINDLY ADVICE SLOW DOWN ON THE SWITCH TAKE YOUR TIME YOU WHERE HITTING THE CAR WAY TO FAST THAT DAY AND YOU WHEREN'T LETTING THE CAR WORK FOR YOU PRACTICE AND IN TIME YOU WILL GET IT I GIVE YOU PROPS YOU WHERE ON YOUR ON SWITCH KEEP IT UP MAN AND REP THE NW ;)
# 9 or #11 MARZ, or the NEW ROCKFARD SUPER 80s :cool:
1 - 11 of 11 Posts
