1 - 20 of 31 Posts
Originally posted by #1baghater@Feb 1 2010, 02:29 PM~16477151
and it gives me a stiff ride and i dont like it so i should just ride on smaller coils
if it gives you a stiff ride you dont want to cut more coils off...that will make it worse
and if you dont like a ruff ride go accumes or go bags :angry:
lol no bags for me well art from hoppos told be to run a smaller coil like a 2ton and you will have a better ride
yeah a taller lighter weight coil will give you a better ride on flat streets,but when you hit bumps it will float up and down like a boat for a min-i like a stiffer ride myself-i dont mind if my shit rides like a 1960 truck lol :biggrin:
but you can run stiffer springs and accumes if you want a much better ride,and you can shut accumes off if you want to show off because you dont wanna hop ect with accumes :cool:
lol it dont really bother me i just want to show air fag guys how we could have a nice ride to when driving but im just going with a 2ton coil not a short stack a full stack
2 ton is still stiff to me. anything under 2 pumps 8 batts, use the stock front springs in the rear. Thats usually too stiff still for me,but better than 2 or 3 tons most guys think they should have back there
yeah i have stock coils with welded cup on it
the front coils out of a 80s caddy i hear work real nice in the rear...
thats what i got welded to the cup in caddy coils
if you have stock coils they are way smaller than 2 ton coils-even fronts are maybe a 1/2 ton on a caddy....2 ton will be way stiffer than what you got now-the ones you got now are close to the diameter of a dime,2 tons are between the diameter of a nickel and a quarter...just for comparison ;)
Discussion Starter #12
ok thanks homie will post pics of it 2marrow im going to install the coils 2marrow so show how it looks wouldnt it lay out more too?
SO FRESH!!!!!
you can get a good 3 wheel though cause they compress to much but its is a great ride
just depends on how tall your goin...if you full stack it like you had mentioned that thing is gonna sit at or above stock height...gotta cut coils to height you want car to sit :cool:
Day2Day Grind
on the rear of mine im using a coil out of a city transport bus, :0 i used a full stack cut it in half, not sure what the ton ratings are but its super smooth... 2 pumps 6 batts.
i wouldnt know what size those would be :dunno: our city busses have air bags in the front(they drop down to let old feeble people on so they dont have to step up high) and leaf springs in rear
Day2Day Grind
the bus that im talking about is this one, i used one coil from the front and cut it
1 - 20 of 31 Posts
