in the rear of my 64. i want to be able to sit really close to the ground but still have some pretty good lift. im gonna be running accumulators also. what size and what kind of cylinder do i need? do i need coil overs if i have accumulators? do i need springs at all? hit me up with some info thanks.
a 10" or 12" cylinder will give you pretty decent lift. the amount of coil you have determines how low the car sits. you can run coil-over or under, its personal preference but coil over seems to be the method of choice for safety issues. you do need springs in any hydro install.
to make a 64 lay 1/2" from the frame and lift up to the max what those og rearends manage to lift you'll need no more than 10" cylinders and 3.1/2 - 4 wraps of coil.
