1 - 20 of 22 Posts
i have another questions regaurding amps.... i have 2 400 watt subs @40ohms bridged...i need a amp that will put out 800 watts at 4ohm... i was in best buy and seen a 900 watts mono amp... but it only puts out 100wats @ aohm... i need an amp that puts out 750-800watts @ 4ohm...LMK
I WOULD SAY A MMATS 700.4 WOULDN'T BE TO BAD. I DON'T KNOW WHAT YOU ARE LOOKING AT SPENDING BUT THATS A PRETTY GOOD AMP JUST SLIGHTY LESS POWER THEN YOU WANT. JUST A IDEA. I FOUND THEM FOR 429 OR 419 FOR THE 700.2. THE 4 AND TO ARE FOR OHMS. HOPE THIS HELPS.
JL 500/1 it pushes over 800 .. mine metered at 837 watts and i have two of these amps pushing two 10'' jl w7's ..... really nice sound quality i havent really noticed any downsides to this amp has more adjustments than i will ever used....i picked mine up for 350 but i have a hookup if your in a city you could probably find one for around 400-450 easily
Discussion Starter · #19 ·
is that at a 4ohm load???
the jl amps dont change wattage over the impedence they push the same exact thing...a little better sq in the higher impedences though and yes that is in 4 ohm....shop around if your going to go with one of them though list price is like 600 but i find them for around 400 pretty often through dealers so you still have a good warranty....main reason i like them is because of the features..
1 - 20 of 22 Posts
