i would run them ported and use one of the punch amps to both. But you need to check and see if that amp has a subsonic filter built in with itOriginally posted by ferns213@Oct 15 2003, 01:30 AM
what would be better "box" and iam only thinking on the amps i talk't about
the 301 only does 300 rms so i would go with the jbl amp but if you want to go ported u will need to use a subsonic unless you port the box lowOriginally posted by 91lacdeville@Oct 16 2003, 12:53 PM
it should say if it has a subsonic filter but i will check for u
900 peak but only 300 rmsOriginally posted by ferns213@Oct 17 2003, 04:18 PM
they were rated at 900watts eatch?
i got an even better amp for you. How about BuThatsaCHRYSLER amp. Its better than the jbl and I believe it had a built in subsonic filterOriginally posted by ferns213@Oct 17 2003, 08:52 PM
ok i dont knoe what that is but i bet its not good so i quess i'll bet the JBL
