And yes another idea.
Just some thoughts to share.
The perfect pump, it would be about the size and weight of a group 31 battery. It would have only one outlet port and have the dump and check built in. There would be no block or manifold. Just a tank gears and plate for the motor. The motor would be a custom heavy duty 6 volts or even 9 volts. The dump would be a custom designed Adex and no need for a slow. The pressure port exits at the front end of the tank. You can run a straight line or angle.
This design is like a aircraft setup, except the tank surrounds the gears, and valve and there is no block/manifold.
If you needed a slow, there would be an optional model. The slow down would be inside the tank and the handle would extend outside
There would be a replaceable module that would be a fan with cooler fins at the end of the motor.
Benefits: fits right in place of a group 31 on your battery tray. No outside plumbing. A square tank that also surrounds the upper part of the motor may provide more fluid.
Comments??
Comments??
