Hole saw is your best option slow speed use oil and be patientI tried that I went an got a hole saw pit for metal it has a drill bit in the center ... It snapped 1 drill bit already an it keep jerking the fuck outta the drill ... I can't even start it off
YupPower drill with a hole saw
Good ideaIF YOU HAVE A SOMETHING TO WELD WITH, get the right size hole saw and then find A pierce of pipe that is the same ID as the hole saw OD . Cut a small piece off it and tack it to what ever ur trying to hole saw , the pipe will keep the hole saw from going all over the place and you wont need any drill bit to keep it in place......
oil or any lube will keep it cool and working smooth.. If to much heat it will eat up the hole sawAlright cool it won't cut with out oil or it just makes it easier ?
Bi metal is what you want.Thanks for all the info is there a metal only hole saw ?? All the ones I've been seeing are the bi metal hole saws an the teeth on them look to agresive for thick metal ?
