1 - 9 of 9 Posts
that really tight, clean look. i have done fabrics and some looser leather ones but i mean new leather thats still firm etc. just trying to learn thanks in advance.
my bad interrior wise i want the leather to be really firm and tight this is my same car just not mine and im gonna do the same thing just bought it a couple days ago now time to put in some work on it its a 97 caddilac catera with 77k miles
I would buy already loaded headrest and then re-wrap them to the color of your interior! Thats what I did,, then if you sell the car you can put back in the stock headrest.
ya but im not tryin to rewrap might dye them tho with sem?
you can steam the leather, that will make it easier to work with.
:cheesy: thanks ya thats a idea i just want them to remain firm and tight
PIMPIN'AINT DEAD
i guess the only advice i can give u is when u cut the headrest and start ripping foam out test fit as u go so u can have the fit ur looking for...the material goes tucked between the tv and headrest bracket so i dont see how it will not remain tight and firm unless u remove too much foam/padding or cut the the material slightly larger than needed
also another tip: i usually use spray glue to the material and then press the tv in the bracket for a firm and tight fit and most of the time u can screw the headrest bracket to a plastic or metal support inside the headrest itself to assure a clean install and have no issues
If you can't get a screw in there another trick you can try is using zip strips to the headrest pipes. (if that makes sense)
Wrap a zip strip around the mounting post and then through the TV mounting bracket and pull tight. That will get the screen tightly into the headrest as well. ;)
1 - 9 of 9 Posts
