1 - 8 of 8 Posts
Either motor or pumphead?
What It Do? Hydraulics
Check motor to see if oil is in it...If so the Pumphead isn't on tight enough to produce pressure you need. If this is the case u need to change the seal. If pump in new make sure check valves aren't on Backwards!
1 - 8 of 8 Posts
