1 - 17 of 17 Posts
i was taking off my stock rims off 89 towncar and on the first lug to come off it striped the stud on the end 3 treads of stud.my ? is, could i file down the strip treads or cut it off right where the good threads start,or get a new one ?it does not look that bad but i never had this type of problem before can someone help asap.
most studs are pressed in u will have to beat on it to get it out
Originally posted by Payasomm@Jul 28 2003, 09:49 PM
sometimes my lug nut will get stripped, maybe Im tightening them to much. Does anyone know how many foot pounds to tighten them, I have a 77 monte
i would never tighten them to more than 100ft/lbs.
Originally posted by Foompla@Jul 28 2003, 01:32 AM~923847
just one?  that fucker took me all day to get out when it happened to me
what kind of hammer were u using...a plastic one? time to get a real one. a nice 48 ouncer is what i use sweetheart. one good tap and poof its out.
how do you actually know how many pound u have applied? is there any digital device of digital ratchet that can measure pounds as it is tightening?
You're telling me you have never heard of a torque wrench??? Please go buy one right now. Your car will thank you.
:thumbsup: A torque wrench should be everyones best friend. Unless you beleive in the German goodNtight...method of torque.
steel rim, 80 ft lbs
can anyone give me basic guidance on how to remove the disc, i need to replace that and my studs from a recent problem with my spokes, messed up the tread and my disc needs to go anyway,,, i know how to remove caliper, how would i go about removing the disc, from the back? i just wanna see if its common sense procedure if not ill leave it to my homie at the shop to handle it...
1 - 17 of 17 Posts
