1 - 17 of 17 Posts
I need some help with my 13's on my Monte!? one wheel is not going flush on the Drum and it's causing the wheel to vibrate and make some noises. I thought that it might be the weight that was on the drum so i grinded down the weight alittle and it still did the same thing. I then put another drum on my monte and it still doen't help.... My Monte is 1984 thanks in advance homie's!!! :confused:
first off you need to check the center hole in the wheel and make sure it is a little bigger than the axle. maybe the center is hanging up on the axle as you slide it on. next maybe make sure the wheel isn't bent. because when it's bent in the center it's alot harder to see than a bend on the barrell or outer lip.and are these wheels ko's or bolt ons?
No the lug nuts are the right size and the balance on the tires should be fine. When we mounted them on they didnt seem to fit right. Im not sure what its hitting or if the adapter is fucked up. It also could be his axle. Ive never had any go bad on me on a g-body but you never know.
In Due Time!!!!
i got a bad adapter from player, i think it was out of round. i caused my wheel to come loose twice while i was driving and scared the shit out of me. after the second time, i was hammering the k.o. and one of the ears broke off. i ordered another spinner and adapter and havn't had a problem since. unfortunately player doesnt include this shit in their warranty so i actually had to pay for it. so, i would try borrowing another adapter for a test drive and see if this is your problem. let me know how it goes!
1 - 17 of 17 Posts
