I need a new frame for my 70 Monte Carlo I found out mine is cracked under the frame by the between the upper and lower A Arm right next to the crossmember.
Banned
Junk yard, and hey if you do not find a frame, at least you had fun at the Junkyard.
when you go to the junk yard, ask them to check the "hollander"..
its a interchangability manual that will tell you if there is any other frame you can use, maybe a cutlass or grand prix from the same era, than you have more options.... good luck...
weld it back :biggrin:
