1 - 12 of 12 Posts
i under stand the black objects to the lefts are air springs, but they attach to the 4 - link in some type of air strut set up, those air springs are shockwaves...how would i put slam specialties there and how is this triangulated 4 link suppose to give me 3-4 inches of strock for every 1 inch of bag...if you have to put the bags where the bags are shown here, i dont see were this "pivot point" would be
Face Puncher
with them mounted there, it's like a 1:1 ratio..
sandwich the bag between the front of the lower arm and the frame, then you have some multiplication factor going on...
thanx 4 the drawings bigdan but in that second one, where the bag is position on the 4-link and fram, wont the bag lift the frame right off of the 4-link? is that second drawing safe i dont see where you would put a bag mount on one of the links itself, how will it stay on/hold on
Face Puncher
um, the lower arms of the 4 link are mounted to the fram rails...
so all you're doing is moving the arm on the pivot...
you could weld a flat plate to the lower arm to mount the bag onto..
do this for an example..
grab a pair of scissors, and a quarter..
the quarter is your airbag and the blades are your lower link and frame...
put the quarter in between the blades all the way at the tip..
see how far the scissors are open?
now, slide the quarter toward the pivot, notice how much further they open as you do this..
that is the advantage of having the actuator near the pivot..
1 - 12 of 12 Posts
