if ur wanting some inches i would suggest some koolaid coils 4.5 ton. cut 1 turn off and youll be good up front. also i recommend that you sink the lower a arm pocket on the front. otherwise the coils may kick out and shoot out sideways, cuz the diameter of the coils is slightly larger than the diameter of the spring pocket in the lower. on the rear end its hard to say the coil choice becuz youll have a lot of weight back there from 12 batteries and it may lay on the floor.... we did a car and stuck i believe either 4ton or 4.5 back there. but since your driving it ill assume that the rear end will be raise up to a good ride level and you may want to try 3.5 ton coils in the rear. or use the 3.5 ton coils in combonation with accumulators. that will make the ride nice and soft in the rear.Originally posted by beemc@Nov 14 2008, 06:27 PM~12159525
i need to know what coils to put on my 63 front and rear i will be driving the car alot but i want to get some inches out of it i plan on running one piston to the nose and 12 batts
