To me I think they are soundstream ??what do you think of the specs
Specifications: *Power Handling: 800 watts RMS *VCdia: 3" *Le: 2.5 mH *Nominal impedance: 4 ohms per coil *Re: 3.0 ohms *Frequency response: 20-300 Hz. *Magnet weight: 192 oz. *Fs: 34 Hz *SPL: 90 dB 2.83V/1m *Vas: 1.2 cu. ft. *Qms: 5.33 *Qes: .39 *Qts: .36 *Xmax: 18 mm *Dimensions: Overall Diameter: 12-1/2", Cutout Diameter: 11", Mounting Depth: 6-3/4", Magnet Diameter: 8", Magnet Height: 3-1/8"
Dual 4 ohm voice coils
Powder-coated cast aluminum frame
Massive double-stacked 96 oz. magnets with protective boot
Long excursion heavy-duty foam surround
Two flat spiders with integrated speaker leads
Vented pole piece
Made in USA
Vented pole piece
Made in USA
