1 - 20 of 35 Posts
24 volts is slow,actually when your volts are lower is kinda bad in a way so is high volts cause it can break things,with low volts you can leave arc welds inside your motor on the armature causeing it too stick,same way with a solenoid,it sticks then your motor keep running giveing it constant power,theres a downfall either way,lol i say run atleast 36 - 48 for daily,also with 24v you will probally be charging your 2 batterys daily,lol
how would 2 batterys cause an arc weld inside the motor? these motors are 12 volt motors. think about lift gate trucks, they all run on 12volts and all we are using is pretty much refined liftgate pumps.
if your batterys go dead, which they will go dead quicker and it can cause your solinoids to weld shut and well you know the rest.
12 VOLTS!!!!!!!!! WTF!!!!!!!. You probably can't even fill you're cylinders up and you must be charging every 10 hits of the switch..i know from experience.....hahaha.
24 volts gives good speed but 36 will last longer. Good Luck.
thanks guys i put 2 optima yellows wired at 24 volts
works really good. batts sem to go for a long time too
but now if i am goin down the street and lift it the driver tire comes off the ground
is this ok or should i not hit them goin down the street
Hydraulic motors need at least 36 volts to run and switches need 24 volts. If you are only runnin 24 volts you are gunna be burning up soliniods all day. If you want it slow then just close the slow downs until you get the speed you want
Originally posted by slamed87lincoln@Aug 10 2005, 04:06 PM~3583961
24 in my opinion is pretty slow ...id atleast run 36-48
36 was too slow for my taste actually, I reccommend atleast 48 for nice response, but not back breaking
Shit 60 volts was too slow me! LOL... How in the hell were you only running one battery though? You need atleast 24v going to your switches. How does that work? :dunno:
how do you figure 24V to the motors burns up noids? my wagon was setup that way as a daily driver. it has 2 carquest brand noids per pump and i never burnt a noid?
im not praising 24V to the pumps but it does work, 36 is quicker and batts last longer. speed is still slow, but not everybody is tring to be fast.
Discussion Starter · #17 ·
so i need to add another batt its just a one pump front kit i havent done the back yet and also my pump and battsare under the blazer could'nt fit them inside my woofer box is way too big and did'nt want to give up the tunes
Id just forget the box lol.. Nah got any pics of the setup? my mini trucks have the batterys / pumps under them too.
see, i told you guys you can lay frame with a 4x4
1 - 20 of 35 Posts
