THEY TOO BIG IN SIZE 52X22X20Originally posted by Firefly@Sep 20 2006, 08:21 AM~6208674
I wouldn't take my chances with that. It would work, but not so well.
Try to get a hold of some batteries with at least 1000 CCA.
SOORY IM TALKIN CANTIMETEROriginally posted by lowered_impression@Sep 20 2006, 11:06 AM~6208850
here walmart sells optimas for under $100 also your measurements are way off. You need a group 31 deep cycle
any battery would make the car up and down but they're gonna run out quick and you won't get 100% response from your setup like you're supposed to.Originally posted by TAIB@Sep 20 2006, 07:09 AM~6208853
WILL 650 CCA DO THE JOB
One thing that you can do is get the batteries you want and if they are low cca, then just wire 2 at a time in parallel and then run them in series after that. Just make sure you are useing all the same type of battery with all the same cca and make sure thay are all new.Originally posted by TAIB@Sep 20 2006, 12:25 AM~6208509
I GET EM FOR GOOD PRICE BUT I THINK THE CCA IS TOO LOW
WE AINT GOT SMALL SIZE BATTS WITH HIGH CCA HERE
ONLY OPTIMA FOR A LOT OF MONEY
