I was wondering again fellas if I were to take off my front stabilzer bar or aka sway bar and get a higher lift on bags? Cause by looking at it, it seems like its holding from getting higher, or am I wrong and it'll get just as much with it on?? :dunno:
check to see if your upper bump stops are in. yes there are some on the front of the chassis that keep the front from going too high. if you do not want to remove them, cut them down. you can see them when vehicle is at normal ride height and they sit just on the frame out towards the spindle on the spring pocket.
I disagree, I feel that unless the sway bar is binding at high lift, there really shouldn't be any difference in lift. It will definitely affect sides, but when the suspension is lifting evenly the sway bar has no affect. Just make sure the end links arent causing the bar to get pulled when lifted up and there should be no loss of lift.
real husler
THE SAME AMOUNT OF TRAVEL EITHER WAY
Face Puncher
the air pressure fights against the sway bar when its attached. removing it gets rid of the extra force required to raise the car. but ya, you wont get a higher lockup by removing the bar, you'll just lock up at lower PSI and the ride will be better due to the decrease in pressure. the only thing that would make it lift higher by removing the swaybar is if the system was underpowered to begin with.
