1 - 2 of 2 Posts
i bought a window motor for my 83 fleetwood coupe i thought it would be a easy install but its connected to a plastic thing with a rivet i know i have to drill the rivets holding the actual motor but what will happen when i separate the motor from the plastic gear can someone give me directions on how to install motor thanks
I hate doing window motors because you can never get your hands behind the sheet metal. But, the new motor should align the same way as the old one. Just make sure the holes on the motor are lined up with the holes you drilled.
1 - 2 of 2 Posts
