what will happen if u reverse the polarity on a dump
W whitegold1234 · Registered Joined Feb 9, 2005 · 143 Posts Discussion Starter • #1 • Aug 13, 2005 what will happen if u reverse the polarity on a dump
D dreday · Registered Joined Sep 29, 2003 · 4,710 Posts #2 • Aug 13, 2005 You can't wire a dump backwards
W whitegold1234 · Registered Joined Feb 9, 2005 · 143 Posts Discussion Starter • #3 • Aug 13, 2005 i waj just wondern if u did if it would close faster
D dreday · Registered Joined Sep 29, 2003 · 4,710 Posts #4 • Aug 13, 2005 Doesn't matter, its the same either way.
W whitegold1234 · Registered Joined Feb 9, 2005 · 143 Posts Discussion Starter • #5 • Aug 13, 2005 ok thank you
schmidt64 · Registered Joined Oct 31, 2002 · 4,190 Posts #6 • Aug 13, 2005 the wires on the dump will deliver the same results no matter how you hook them up
S Swingin80Lincoln · Registered Joined Feb 17, 2003 · 2,716 Posts #7 • Aug 13, 2005 .....unless its an adel/adex.
W whitegold1234 · Registered Joined Feb 9, 2005 · 143 Posts Discussion Starter • #8 • Aug 13, 2005 what will the adels do and what is different that causes it the candel
schmidt64 · Registered Joined Oct 31, 2002 · 4,190 Posts #9 • Aug 14, 2005 they won't work at all cause one wire is the designated ground
