any1 kno how to wire tha headlights so all 4 of them go on?? its for a 81 mc
They should..mabey a switch problem. Use a relay.Originally posted by schmidt64@Sep 7 2005, 10:44 PM~3774119
low beams should stay on when you put the high beams on
I'm almost positive you can't because the high beam bulb assembly is a higher output only, unless you put a dual high/low beam bulb in place of the high beams. Which is going to require some drilling, wiring, etc.Originally posted by FullFledgedPimpin@Sep 8 2005, 01:17 AM~3774537
cant i make it so wen i put tha low beams on.. all 4 r on low beam and wen i hit tha high beam switch all 4s become high beam?
i like this idea...but sometimes...you just need those high beams...its not like they're that bright on g-bodies anyways....look!!!Originally posted by cashmoneyspeed@Sep 8 2005, 01:07 AM~3774240
replace the high beams with regular bulbs and you won't have high beams anymore but you probably won't need em and the cops wont stop you for driving with high beams on
AND WHEN THE HIGH BEAMS COME ON ARE THE 2 INNER LIGHTS SUPPOST TO COME ON OR ARE THE LOW BEAMS SUPPOST TO GET BRIGHTER
BECAUSE ONLY 2 LIGHTS COME ON
I CANT GET THE 2 INNER ONES TO TURN ON :angry:Originally posted by RALPH_DOGG@Sep 13 2005, 11:18 AM~3804625
on mine...2 outer ones are low beams and 2 in the middle are high beams....you can change them around though...
yea i wasnt thinking about it when i drew it up.Originally posted by 84RegalRider@Sep 14 2005, 05:38 AM~3811378
Whats up with the resistor???
