is there anyway you could extend a wish bone from a lincoln? if there is please explain?
yea the lincoln wish bone .. do you or anyone else knows if you could extend them ?Originally posted by OUTHOPU+Aug 17 2006, 10:53 PM~5990938-->ookkk i dunno what you would call it but anyone who knows about lincolns or fords or w.e know that from 91 down the upper arms are wishbonesAre you refering to the upper A-arm? If not where is the part your talking about located on the car? I think you may be calling the part by a different name than most people know it as. What year and model of Lincoln?
[/b]
and as for the model of lincoln its a 96 but all the the lincolns from 91 and til this present date da uppers are wishbones
<!--QuoteBegin-impala_631@Aug 18 2006, 01:04 AM~5991728
the lincoln wishbone????
Originally posted by wannahop@Aug 19 2006, 03:00 AM~5999341
i have a 95 same as yours exstended 1.5" and renforcedill put some pics up 2morrow
PICS :biggrin:Originally posted by wannahop@Aug 19 2006, 01:00 AM~5999341
I think its more of a y-arm :biggrin:Originally posted by SwitchHitter@Aug 18 2006, 11:10 PM~5998281
yes hes talking about the lincoln wish bone, the upper a-arm. duh!
what your calling them makes sense due to the look of the arms...but ive never heard them called wishbones....weird lol.....if you want you can switch out the arms from an 80-91 lincoln towncar and youll be better off.....but they do say that you can reinforce and extend (as the pics above show) and it will be just as good...to be id rather rely on steel arms than aluminum arms...just me though...Originally posted by 96' lincoln@Aug 19 2006, 01:14 AM~5999035
the older arms are a pain in the ass to get the stock balljoints out but once you replace them with the bolt in ball joints there no hassle at all....4 7/16s nuts and bolts....2 wrenches also....and also the boot dont get messed up on removal....only when you remove the press ins.....i use the Napa Heavy dutys for my lincoln...no problems at allOriginally posted by OUTHOPU@Aug 19 2006, 09:48 PM~6002429
I didn't preheat but you could if your concerned about it.
The arms are not aluminium or cast iron, some sort of steel mix.
The stock arms may be strong but they do not offer enough adjustment at the ball joint to get the length we were after.
I would not swap for the older stuff, these are way easier to service. You can change a upper ball joint with 2 wrenches and since the ball joint is not a press fit you can get it apart without using a pickle fork which always destroys the rubber boot.
yeah the older ones do have the tapered shaft....but the weight of the car presses them where they need to be....the Napa HDS are great...been on my car over a year now and i have not been easy on it.......the newer arms do look simple compared to the old ones....either way it looks good installed...theres been quite a few people that say they have extended and reforced the newer arms but i belive these are the 1st pics to be posted about this subject...nice workOriginally posted by OUTHOPU@Aug 19 2006, 10:17 PM~6002621
NAPA HD ball joints are a must for any lifted car. The older ball joints are a tapered shaft that is a press fit into the spindle isn't it? If so thats what I was refering to, getting the ball joint out of the spindle is super seay on the new ones since they just use a bolt through the spindle that lines up with a notch on the balljoint shaft. I like the way the ball joint mounts to the arm on the new ones because there are 2 studs that dont spin so you only need one wrench to get them off the arm, the second wrench removes the set bolt that passes throught the spindle.
We were looking at some of the older arms but the ball joint angle is not the same on the older cars. It may not matter but I just didn't think it was a good idea since it would have changed the caster angle pretty severely.
