1 - 8 of 8 Posts
i am looking to buy 24x8 rims with 275/25/24 tires......holla at me... 2000 grand marquis pm me or post up...
Is it bagged or something? Is that why you want such a narrow wheel?
Because you can run a 24x9.5 or 24x10 no problem.
And YOU WILL NOT LIKE THE 24x8's they look like straight shit, way to narrow, believe me i have em before and i even felt bad and said to myself "that looks like shit".
Maybe on a honda accord or some small shit but not a marquis the wider the better.
haha
well the only reason i was thanking 24x8 is because the last set i had was 24x9 i am wanting to say they had a 30offset i cant remember but like the edge of tire sat right under the fender lip so with out a little bitty lift once i hit a bump it would cut the tire....so what i am trying to get to is ...i want my rims and tires inside the fender this time i do not have to have a lift and i can get alignment and be good to go without having to worry bout the inner and outter of my tires going ball b/c of the lift....so should i just go with a 24x9 and get a different offset? i really have no idea about offsets.... or what offset i should be looking for......with a different offset will it change the lip size and face father in or out...
sorry for blabbling on but i need help on this ...thanks alot
stock suspension
bump^^
~Maniako Enfermo~
Originally posted by WhitePapi2006@Jan 30 2010, 09:15 PM~16464113
haha
stock suspension
jest take your car to a rim shop and try some on... then buy them there.. that will get you what you want.. if not then you're in for some headaches...
<<<<not worried about it NORTH TAMPA CUSTOMS GOT ME....
1 - 8 of 8 Posts
