1 - 5 of 5 Posts
ok i checked it and it had a th-350. My next question is the car right now has a v6. i have a small block v8 go n in it will the cross member still work for the swap or do i need to find a v8 car crossmember?
the crossmember will work. but you may need to modify it for dual exhaust, you may have to notch it on the passenger side. otherwise itll work for a th35o or if you want a powerglide
1 - 5 of 5 Posts
