1 - 20 of 22 Posts
How much do you guys trim on the X Frame with 14" Cylinders For Driveshaft Clearance?
SGT AT ARMS
depends on what size cylinders in the rear
14"
Originally posted by SIK_9D1@Mar 9 2010, 05:47 PM~16841811
14"
we cut all the way up the tunnel until ur about 3-5 inches away from the carrier bearing mount..
Thanks KingFish! :thumbsup:
over it
When you do it use a hole saw to make the end of the notch by the mid bearing. Then just cut the tunnel out. Doing it that way will be stronger. Cutting a notch and leaving it square will cause a stress riser in the corners which can lead to cracks and faliure.
good tip..i never thought of that...i learn something new once a month lol
over it
Oh and it looks nicer. Thats just an opinion though, was trying to stick to the facts. ;)
ur right though..it would put stress in the corners...no reason why not to try to prevent as much as u can...
PINCHE GABACHO
DAMN I OVER LOOKED THAT... THANKS FOR THE REMINDER ;)
LOL ya good tip for sure. def. makes sense :biggrin:
Ok cool, I'm thinking If I trim the upper cups on the rear bags that may help, figure that would be a good idea to try first, I only need to go down in the back about another 2inches or so to be level when im layed out, but if I wanna go lower I'm guessing frame notch would be the next move, I appreciate the info man
1 - 20 of 22 Posts
