[attachmentid=281673]
[attachmentid=281676]
[attachmentid=281678]
[attachmentid=281679]
[attachmentid=281675]
XENARC 700TS™ / 700TSV™
7" TFT LCD Touchscreen Monitor w/ VGA & Optional AV inputs
Now with 5-Wire Resistive Touchscreen!
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with VGA input and Touchscreen. In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector.
This popular product incorporates the innovation of our VGA 7" models along with a 5-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 700TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an instruction manual, a copper monitor stand, an AC adaptor, a connection cable, cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Linux, and Mac OS.
To install this monitor in a vehicle, check out our Headrest Mount, Model #BSM-1. Please also take a look at the non-touch version 700Y / 700YV if you don't need a touchscreen.
- Available in Silver or Black
This widely acclaimed monitor is featured in T.W.I.C.E. Magazine, 12 Volt News, AUTOMEDIA Oct. '03, Mobile Electronics Nov. '03, IMPORT RACER Mar. '04 - S2000, EUROPEAN CAR May '04 - Uber M3, RIDES Winter '05, the Rockford Fosgate H2 Hummer Show Vehicle, and West Cost Customs P.M.R. - Get the best, get XENARC
Features
For In-Car Computing, PC, Server, GPS, and various VGA Use
5-wire resistive Touch Screen (USB) *New*
Multi-Monitor Touchscreen Support
VGA Input (15 pin D-SUB) x 1 (700TS) or VGA Input x 1 & Video Input x 2 (700TSV)
Audio Input / Built-in Speaker (700TSV)
NTSC / PAL Multi-System (700TSV)
16x9 Aspect Ratio
High Resolution Display - up to 1600 x 1200
Upgraded High-Brightness CCFL Backlight
Adjustable backlight level for night-time use
Pixelworks High Performance Video and VGA Processor
High Quality Scaling & Anti-Aliasing
16:9 / 4:3 Scaler settings *New*
Last Input memory (700TSV) *New*
Last Power setting memory *New*
IR Remote Control (700TSV) *New*
Auto power-on upon signal detection
Automatic display adjustment
On Screen Display Control
Metallic Silver or Black Casing
Copper Stand: 360° / Height Adjustment
20-Pin heavy-duty connector
Anti Glare Coating
Supports 11V DC ~ 24V DC
"E" Mark Certified for Automotive use
Compare Features
Specifications
Model #: 700TS / 700TSV
Screen Size: Diagonal 7" (16:9)
Physical Resolution: 800 (H) x 480 (V) WVGA
Supported Resolution: 640 x 480 ~ 1600 x 1200
Dot Resolution: 2400 x 480 = 1,152,000 (dots)
LCD Brightness (w/o Touchscreen)*: 400 cd/m²
Display Brightness (w/ Touchscreen): 330 cd/m²
Touch Screen Interface: USB port
Operating Voltage Range: DC 11V ~ 24V, 1A
Power Supply: DC 12V
Power Consumption: <8W
Operating Temperature: 23°F ~ 158°F
Dimension (in): 7.75W x 4.75H x 1.38D
Weight (lb): 1.28
FCC, CE, E13 Certification
18 Month Warranty
30 days No dead Pixel Guarantee
*LCD Panel Manufacturer's test result based on specific test environment. Number corresponds to maximum output and should not be confused with typical output. Typical output has to compensate for different factors and is also reduced to prolong the life of CCFL.
5-Wire Resistive Tochscreen Advantage:
5-wire resistive analog technology is superior to 4-wire, 8-wire and resistive matrix technologies
Most durable resistive analog - drift-free operation even when exposed to temperature fluctuation
Life span of 35,000,000 touches versus 1,000,000 touches from 4-wire resistive
Increased optical clarity equals higher brightness and a sharper display
Greater touch point density means better accuracy
Faster response time and increased speed
No external electronic correction needed
All this means, our great product gets even better while the price stays the same. While others are constantly cost cutting by switching to cheaper, inferior components, Xenarc is constantly working on bringing you the best products with the most advanced technologies.
HIT ME UP FOR PRICES , IF YOU WANT TOUCH SCREEN OR NON TOUCH SCREEN
Features
16x9 Aspect Ratio
Anti Glare Coating
Compare Features
Specifications
Weight (lb): 1.28
18 Month Warranty
