1 - 20 of 53 Posts
PLEASE PINN THIS TOPIC,
WE NEED IT to HELP OTHERS.....
Okay, to help others, lets all post what we have as a set-up, then others with the same rides can determine what they need to achieve their goals..
please don't post bullshit, or what your friends have, and PLEASE don't ARGUE, USE PM's for that, or a different post, LETS KEEP THIS ONE A GOOD ONE..
post pics of your highest hop if you can
HERE IS ONLY AN EXAMPLE and all the info we need for this post;
(don't count this one)
I have a 1963 Impala Hard Top
3 ton coils up front
60 volts to a SP
1/2" ports
#9 marzocchi
10 batteies in the trunk
38"
PS, I KNOW THAT THERE ARE TONS OF VARIABLES but IT WILL NARROW IT DOWN FOR MOST PEOPLE..
90 Mazda... Radical dancer
4- Black Magic pumps, 12 batteries, delta dumps... 14" cylinders all around... a-arms front and rear. No motor or trans..
84 Town Car.. Daily cruiser.
2- Custom 5" Black Magic pumps, Custom square whammy tank, 6 Batteries... 8's front and 12's rear...
hopefully I will actually INSTALL it in the Linc. soon... ;) :uh:
right now i have
87 fleetwood
3 pumps running single to the front
3 deltas :uh:
8" and 14" cylinders
8 batterys
not sure what size coils up front
only hits a foot or so
the pumps are for sale, i want to get 4 new pumps and adex some 4 ton coils and run 12 batts next year
1995 Cadillac Fleetwood
2 pump setup with SACO HD's and 4 dumps
6's and 12's
Chainbridge
6 bats
2.5 tons up front and 2 tons in the rear with accums
1986 Monte Carlo SS
2 Pro Hopper LA Series Pumps
3/4" Port
#9 Marzocchi
3 Ton Front
8" Front
48 Volts front
2 Italian Dumps
2 Pro Hopper Comp
3/8" Port
#6 Marzocchi
2 Ton Rear
10" Rear
48 Volts rear
2 Italian Dumps
88 190e benz
2 fenner pumps
6s up front
8s in the rear
standard coils cut down with standard shocks
3 batts 36v
4 delta dumps
sensible daily car
84 pontiac project
4 blvd pumps
10 batts
adex dumps
4.5 ton coils up front
2 ton in the rear
8s front
14/16s rear
dunno how high it will hop as i havent installed it yet
1997 Chrysler LHS - 124,000+ miles
Serious daily driver
2 old school lowrider pumps
8 Delta dumps
48-volts from 4 Interstate batts
6 solenoids
remote and local disconnects
6" front / 8" rear cylinders
4 accumulators charged 175 psig front / 125 psig rear
built-in and alternator charge
no switches; old-school Atari joystick and 8 momentary buttons
91 Fleetwood Brougham
4 pump, showtime 1/2 port blocks
#11 Marzocchi front (72 volts)
#8 Marzocchi rear (48 volts)
Saco HD motors all around
Accurate solenoids
1 Adex dump front
2 Oil Systems dumps rear
12 Trojan group 31 batts
8'' ProHopper comps w/ full stack ProHopper 4 1/2 ton front
16'' ProHopper comps rear w/ 1/2 stack ProHopper 4 1/2 ton rear
Best hop to date: 39''
IN MY 95 FLEETWOOD I HAVE..
4 SHOWTIME COMP. PUMPS(1/2 PORTS)
4 BLOWPROOF ITALIAN DUMPS
MARZ.#10 IN FRONT PUMPS
MARZ.#8 IN REAR PUMPS
ALL HARDLINED
6'S 1/2 PORTS IN FRONT W/CUT OFF ONE TURN OF A FULL STACK 4 1/2TONS
EXTENDED AND REINFORCED A-ARMS
14'S 1/2 PRTS IN REAR W/ COILOVER CUPS AND SHOWBALLZ
I TOOK ONE 3 TON COIL AND CUT IT IN HALF
REINFORCED AXLE AND TRAILING ARMS
ALL REINFORCED AS MUCH AS POSSIBLE W/O TAKING BODY OFF FRAME
10 BATTERIES
HIGHEST I HAVE HIT IS ABOUT 30-32 INCHES IN MY DRIVEWAY
BUT DOWN THE ROAD ---I HAVE KNOW IDEA :)
88 blazer
5 batteries
single front pump
#7 head
3 ton short springs
3/8 everything
29 inches at best, always over 2 feet.
88 toyota
12 batteries
double front pump
#11 heads
3 1/2 ton full stack springs
3/4 fitting and 1/2 inch hoses
a little over 80 inches.
85 chevy S-10
16 batteries
double front pump
#9 heads
4 1/2 ton full stack springs
1/2 inch everything
highest hopped so far is 115 inches without raising the rear.
i gotta 89 fleetwood 3pumps 2 reds to the front 1 propper to the back 8 ' up front 12' in the rear 6 bats at 72 volts 5 tons up front and those cute little coilover springs out back 9 solenoids 12 switchs :cool:
78 cadillac coupe
2 pumps
front pump- lona n sons wicked pump w/ 1 dump and a # 9 ph
back pump-old school reds w/ 2 dump in the block and a # 6 ph
8 in pro hoppers to the front w/ 3tons
10 in pro hoppers to the back w/ 2 1/2 tons
8 batts and 6 noids :biggrin:
1985 lincoln towncar
2 cce comp pumps
8" cylinders in front (porkeys), 14" in the back (pro hoppers)
2 1/2 ton pre cuts in front, mini's on a coil-over in rear...no bridge.
4 batts 1 bay=48 volts.
10 switches NO CHIPPING, just 3 wheeling :biggrin:
1 - 20 of 53 Posts
