Asco1 used 4 of these in his tight 90's impala HW....it lifts the car but doesn't hop it...and if you want to go wireless...there's not enough power in the small rechargeable battery to do some hopping and maybe not even for lifting.
One thing that can be done tho is using the gears that come along with the small car this will help giving the motor more power.
so how many motors would it take to lift it?? i remember the one 90's impala that was copied from an actual life size one...it was tight shit...HEY ASCO, u got pics of it still?
Ohh...I'm sure you can lift it but you will need to use 6V or something...but what I said before maybe with the gears in place it can do the job using the small rechargeable battery.
You can't put 9V on a RC receiver that is designed for...I guess 1.5 to 3V...it will kill it.
What I said before maybe when you use the gearsetup provided with the car you can lift your car wireless.
