g body power window
3.4K views 7 replies 4 participants last post by  chongo1
#1 ·
motor worked fine then we started to put in a door solenoid for shaved handle and she quit workin, didnt disturb any factory wiring got juice two wires that go from switch to motor blue one constant 12v black one has 12v when switch is pressed down im thinking that the problem is the blue one with constant power motor was really hot and only clicks i took wires off any help or guidance would help me out sounds almost like relay is stuck on :dunno:
#4 ·
well put a new switch in that was part of the problem i can roll window up from the door and i can go up and down from the drivers door so it must have something to do with a ground somewhere, its a bumper basher so im not going to waste anymore time on it
#6 ·
Originally posted by goofyx3@Jun 16 2010, 11:53 AM~17804605
should be da switch, they dont have relays they r 5 wire
i put new switch on the pasnger door and it goes up not down but it has power down so its gotta be a ground somewhere but i have no idea, and the drivers door will control it up and down so :dunno:
#8 ·
Originally posted by moneycarlo79@Jun 22 2010, 08:47 PM~17861208
i had the same problem and i found that it was a loose ground on the driver side door , take off the door panel and just follow the ground from the driver side window switch,hope this helps.
thanx homie i looked i thought maybe the motor was the ground not sure
