HIGH HEAT PAINT FOR A CAR ENGINE
7.7K views 21 replies 12 participants last post by  pink63impala
#1 ·
WONDER IF SOMEONE CAN HELP ME OUT THERE.I WANT TO PAINT MY CARS BLOCK THE COLOUR IS CALLED BELIZE BLUE COLOUR # HONDA B_551P AND IT ALSO SAYS IT IS A POLY BASE SUFFIX H (G) .ANYONE KNOW OF A COMPANY THAT CAN SUPPLY ME WITH A HIGH HEAT PAINT IN TYHIS COLOUR? THANKS AND MUCH APPRECIATED IN ADVANCE:D :thumbsup:
#3 ·
The hood of your car gets hotter in the sun than your motor does at operating temp.,just prep that block meticulously(no oil or anything flaking),and it'll last.
#5 ·
auto paint
I've order aerosol cans of paint from automotivetouchup.com they do a good job. I was actually thinking about doing the same thing, but I do know they make a high temp primer and clear. I was thinking the correct way to not to have to do it again, is to use the high temp primer, then the regular paint, then use the high temp clear. This theorecticaly is "sandwiching" your color in between the high temp. Guy let me know if I put way too much thought into it.
#10 ·
Take a wire wheel or something similar and get all of the dirt off of the block, then clean with some type of solvent until the rags arent coming out dirty anymore.. then clean one more time :biggrin: buy a couple rattle cans of high temp primer from ur local auto parts store and spray ur block with that, after masking off all header holes, spark plug holes ETC. then you can spray ur top coat on the block, and clear like u would any other paint job.. u can even have ur local paint shop put ur paint in spray cans for u so u can do the whole job with rattle can. :cool: good luck
#11 ·
:wow: :thumbsup:
#14 ·
I'm not doing a total teardown, should I try to get the stock color off first? I've degreased and cleaned the hell out of it. OK to just skuff it up, prime, and color? Do you really need clear?
#16 ·
THANKS FOR ALL THE REPLYS...... HAPPY CANADA DAY !
SURE IS NICE TO GET SOME FEEDBACK FROM EVERYBODY AND THE PICTURES SURE DO JUSTICE AS IT HELPS GET ME MOTIVATED TO GET MY MOTOR DONE.SINCE YOU WERE NICE TO GIVE ME SOME PICS I WILL RETURN THE FAVOUR ....HAPPY CANADA DAY :D :thumbsup:
#17 ·
So i can just clean area well with a degreaser and dry. Then shoot rattle can high temp primer(what brand is best). Then shoot my base candy then clear.
#18 ·
Basically, yes. If there's a good paint job on it already I would scuff up the old paint for maximum adhesion.. and any brand of high temp primer will do the trick, i've used different ones with the same results. Remember tho, ur finish is only as good as ur prep, so prep the hell out of that block :thumbsup:
