How much to install hydraulics on 63 impala?
1 reading
37K views 18 replies 7 participants last post by  Schidek
#1 ·
Is that about right for 2 pumps 4 battery setup? I didn't think it cost that much. I see 2 pump kits for $1,000 - $1,500.. I didn't think it would cost another $1500 to install it.
Thanks,
Mike
#5 ·
I'm fairly mechanically inclined. But I'm not good at welding.. or should I say, I've never welded before.. Thanks.. I'm researching my ass off.. thanks again!
#6 ·
Where you located at? $2350 I can drop the car off tomorrow... well.. if you were in the Tampa bay area.. which I assume you're not.
#8 ·
typical labor rates for a shop install should be 1500+ it doesnt sound too far off. but alot of shops are different and you get different options with the installs. for example some shop will let cars leave without reinforcements, some wont. some use used batteries some use new. some extend arms some dont and so on. if you decide to find a shop for your work do your homework and ask as many questions as possible, dont be ashamed to learn about the shop your go with
#10 ·
btw 94fleetwoodswanging is in your area I believe, and he does very nice work.
http://www.layitlow.com/forums/6080-94fleetwoodswangin.html
Big thanks, Empire! I'll most likely be hitting you guys up for some more parts in the near future. I just removed the home depot grade 8 bolts that didn't fit your trailing arms.. kinda loose, and put in the proper 9/16th bolts and removed the plastic shrink wrap. Do you use any kind of locktite or anyting on your bolts to your trailing arms? I got lock washers on my bolts.. but was thinking locktite might be good idea. What are your thoughts?
Oh and that Guy lives in Plant City too. Might have to hit him up to assist with fabricating something for a wishbone or ybone.. Which raises another question? Wishbone, Ybone, or upper adjustable trailing arms? I see you sell them all.. I got a 63 Impala.
Thanks!!
#11 ·
they covered most of the bases, but those kits you see don't have batteries either. Out in cali we getting em for 70-80 a pop.
Ybone you don't have to weld to the rear end, just another bracket to the frame. wishbone you have to add a bracket to the frame and to the pumpkin on the rearend.
#14 ·
Thanks guys! So a Y-bone will just mount directly on? No welding involved? I'll have to get underneath my car again and take a look. Does it go where the Banana bar currently is? Then I can remove the panhard bar?<br><br>Much respect to LIL members! Thanks man!
#15 ·
Ditch the panhard bar and cut off the mount on the rear for looks.. then you'll have to drill out the holes on the frame for the y bone. It does mount onto the stock rear end and frame.location were the banana bar is, but obviously you'll need to drill the holes for the other side of the y. No welder needed
#16 ·
I was under their today taking a look while I was removing my bent ass drive shaft..lol That is what I thought I'd do.. drill out some holes and mount it, but thanks for confirming that!
Soon I'll be chasing down a telescoping drive shaft / slip yoke with HD Carrier bearing. Then the Y-Bone, prolly from Empire Customs. I love their 2x3 rear trailing arms!
#19 ·
I've ran the 9 wire, speaker wire, and quick disconnect wire to the front seat. Wired up my 6x9's and lightly sanded and the quick disconnect (so it comes out easy) then mounted it.
I initially wanted to mount it under the seat so I could reach down with two hands and shut off the hydro's in a hurry. But the bolt to the seat on that side broke off and I didn't want to mess with it. So I mounted it between the seat and the door on the floor. Reached down and tested removing.. no problems!
